Esco da MATRIX!!
Marcotrix
Re: Esco da MATRIX!!
#131 Messaggio da Marcotrix » venerdì 23 giugno 2017, 11:44
per chi ci capisce...
Thomann S150-MK2
stereo 8 Ω 2 x 85 W
stereo 4 Ω 2 x 150 W
bridged 8 Ω 250 W
parallel 2 Ω
Frequency response 10 Hz - 50 kHz, -1.5 dB
Input sensitivity 0.77 V / 26 dB / 1.4 V
Maximum input level 21 dBV / 9 V
Input impedance, active balanced 20 kΩ
Signal-to-noise ratio, A-weighted, RMS > 85 dB
Crosstalk @ rated power, 8 Ω, 1 kHz > 70 dB
Damping factor, f=1 kHz, 8 Ω > 150 dB
Slew rate 40 V/μs
Protection circuits Short circuit current limit, DC voltage fault, fuse for power supply, limiter, temperature, mains transients
Indicator lights Power (green), protection (yellow), clipping (red), bridged mode operation (green), parallel mode operation (green)
Cooling Fanless
Power consumption @ half output power, 8 Ω 120 W
Power supply voltage AC 115 V / 230 V, 50-60 Hz
Dimensions (W × D × H) in mm 483 x 320 x 88
Weight 11.5 kg
Thomann TA 450 MK-X
Power consumption 5A
Output power RMS 8 W, stereo 2 × 125 W
Output power RMS 4 W, stereo 2 × 200 W
Output power RMS 8 W, mono bridged 300 W
THD 4 W @ 1 kHz < 0.05 % / 200 W
IMD-SMPTE (60 Hz, 7 kHz) < 0.01 % / 125 W
Damping factor (8 W, 1 kHz) 300:1
Voltage gain 50 × standard
slew rate 40 V/ms
Common mode rejection > 60 dB (1 kHz)
Frequency response 20 Hz ... 20 kHz (+ 0.1 ...– 3 dB, 1 W, 8 W)
Input sensitivity 0.775 V @ rated power (8 W)
Input impedance 20 kW (balanced) 10 kW (unbalanced)
Signal-to-noise ratio 103 dB
Crosstalk < 60 dB
Protective circuits DC, thermal, short circuit, subsonic noise and overcurrent protection
Cooling 2 × two-stage fans (DC)
Operating supply voltage AC 230 V , 50/60 Hz
Fuse 8 A/250 V
Marco_trix
Marcotrix
#132 Messaggio da Marcotrix » lunedì 26 giugno 2017, 13:20
Arrivati gli amplificatori... Thomann S150-MK2 e Thomann TA 450 MK-X...
Ottima fattura pesanti una tonnellata... incredibile cazzata nel s150-mk2 non ci sono le uscite col connettore a banana solo speakon o a filo diretto...
che dire... ho provato il Thomann S150-MK2. adesso provo l'altro che è molto piu grande.
Ultima modifica di Marcotrix il lunedì 26 giugno 2017, 18:16, modificato 1 volta in totale.
Marco_trix
#133 Messaggio da F.Calabrese » lunedì 26 giugno 2017, 15:00
Metto all'attenzione di tutti la tua prova...
MA NON CI TENERE A LUNGO SULLE SPINE...!!! ;) ----- ;) ----- ;) ----- ;) ----- ;) ----- ;)
Marcotrix
#134 Messaggio da Marcotrix » lunedì 26 giugno 2017, 18:11
work in progress
al confronto:
- Nikko TRM230 con i suoi 16watt
- T.amp s-150mk2
- T.amp Ta450 mk-x (la bestia)
- Marantz sr7010
Marco_trix
Ute
#135 Messaggio da Ute » martedì 27 giugno 2017, 9:57
Cut... incredibile cazzata nel s150-mk2 non ci sono le uscite col connettore a banana solo speakon o a filo diretto...
Se è come nel T400, basta svitare del tutto e togliere i morsetti per il filo spellato (fai forza quando sei a fondo corsa, non si rompono) e le banane entrano giuste giuste.
Ripeto, se è come nel T-400.
Le "banane" non sono a norma, e nel pro non si scherza, quindi niente tappini rimovibili e altre "italianate"...
Marcotrix
#136 Messaggio da Marcotrix » martedì 27 giugno 2017, 10:35
nel TA450 ci sono. banane, speakon e filo spellato.
Marco_trix
Ute
#137 Messaggio da Ute » martedì 27 giugno 2017, 11:18
Hai ragione, e può darsi che il 450 sia un progetto precedente all'entrata in vigore delle norme CENELEC, oppure semplicemente non è a norma.
#138 Messaggio da F.Calabrese » martedì 27 giugno 2017, 11:24
Sì... ma come suonano... a confronto...???
danco
#139 Messaggio da danco » martedì 27 giugno 2017, 12:05
Vado leggermente off topic ma sono veramente curioso, dato che questa cosa non l'ho mai capita, ma per quale motivo le banane non sono a norma ?
Danilo
Marcotrix
#140 Messaggio da Marcotrix » martedì 27 giugno 2017, 12:31
è ancora presto per dirlo... perché oltre a capire come suonano, devo decidere se e quale tenere...
non è facile specie a causa dei diversi morsetti.
Marco_trix
